No longer able to make WiFi Calls
354-
Star Contributor
Star Contributor
No longer able to make WiFi calls from smartphone, phone is in safe mode.
- Am connected from a broadband connection, WiFi enable, smartphone's WiFi is enabled, flight mode is enabled, EE cellular - disabled.
Tried calling 150, nothing, no connection. Tried calling another mobile network operator's Customer Service number, nothing connects through WiFi calling.
WiFi Rooster 🐓, what has happened?!
1 ACCEPTED SOLUTION
Christopher_G
Morning @354-
Sorry to hear that you had some problem with your WiFi calling. Could you try restarting your device this morning and let me know if it's working?
7 REPLIES 7
Northerner
Hi @354-
Try activating EE cellular as and taking your device off flight mode.
Likely to be related to the EE widespread network issue going on, and so hopefully it'll be working again soon.
354-
Star Contributor
Star Contributor
@Northerner - Thanks. Though I am not sure why WiFi calling will not work at the moment when EE cellular is toggled off?
Previous in the past, WiFi calling has worked perfectly when the device was in flight mode, WiFi enabled on the device, WiFi calling enabled, EE cellular off.
354-
Star Contributor
Star Contributor
@chistery - hope so too!
354-
Star Contributor
Star Contributor
Went for a "reset network settings" on the device.
IMS registration is now showing as registered after performing the reset network settings.  (Previously IMS registration was "Unregistered".) More time is needed I guess.
Christopher_G
Morning @354-
@Christopher_G - Yes WiFi Calling is now working, had to give it time and rebooted the phone!
