09-10-2026
09:10 AM
- last edited on
09-10-2026
01:38 PM
kh_christelle
Hi I'm having a similar issue but I can't get my questions answered on here it just searches for other conversations with similar words. My new sim card (same phone, same number) is saying it's not provisioned. When I called EE CS they said that the serial number on the new card wasn't even an EE number despite it arriving via Royal mail from EE. I'm now in Portugal with no calls & no texts & having to rely on wifi for Internet. Tried cleaning it, switching on & off etc nothing seems to work.What can I do please?
[Mod Edit - Title added]
09-10-2026 04:24 PM
Welcome to the community.
It sounds like you've described a replacement SIM card. Our customer support team would be able to take the SIM card number and register it to your existing line.
However, like others have indicated here, it would need to be registered and used in the UK for international roaming to be enabled on it.
Once you're back in the UK and it's registered, you will be able to use it for future trips abroad.
09-10-2026 01:35 PM
Your post has been moved to a dedicated thread, that's the best way of getting advice tailored to your circumstances.
Are you on PAYG or pay-monthly? And did you use it on EE's UK network before travelling abroad?
09-10-2026 02:41 PM
Did you activate the SIM in the UK.
09-10-2026 04:24 PM
