Essentials Unlimited plan hard-capped at 12 Mbps—150 support states line is norm
driftererer
I am on an Essentials Unlimited plan (100 Mbps target). My download speeds are hard-capped at 12.4 Mbps across both my phone and mobile hotspot. I have tested it with and without a VPN, and outdoors next to the mast. A moderator needs to review my backend HLR profile because my SIM card is incorrectly provisioned with a 'No Frills' 10 Mbps speed block.
Leanne_T
Hi @driftererer
We have no account access on the community to check the profile and get the speeds looked into. Please try getting back in touch with our tech guides on 150 to get this investigated and see what is needed to help you get this resolved.
Thanks 🙂
Leanne_T
Hi @driftererer
Thanks 🙂
Northerner
Hi @driftererer
What device do you have.
It's Pixel 11 Pro. I used to had 9 pro and the speed was the same always.
