04-05-2023 02:57 PM
I am in Norwich. One month ago I got a proper network but still I didn't get. Can please give the appropriate solution for that and also make sure provide the network coverage all areas.
04-05-2023 04:15 PM
Hello @Justin06.
Have you been able to check your area using the coverage checker?
This will show the coverage you should expect and also if there is any work going on in your area that may affect your service.
Katie
04-05-2023 04:18 PM
04-05-2023 04:24 PM
04-05-2023 05:44 PM
04-05-2023 06:03 PM
Have you been able to try your SIM in another device @Justin06?
Katie
04-05-2023 06:06 PM
The coverage checker doesn't list every conceivable model of phone, but you can safely choose the nearest equivalent to your device, to get a coverage prediction.
