EE 14-Day In-Store Return Due to Coverage Issues
MichaelMD
Hi, I’m looking for some clarification from EE regarding an in-store purchase, a coverage issue and the 14-day return policy. I was already an EE customer and was still within my existing contract, so I was told I could not upgrade at that point. Instead, the EE store opened a new line/contract for a new phone and I was told that doing this would resolve the issue I was experiencing. However, the coverage problem has not been resolved. The phone still has very poor/no usable EE coverage inside the home, particularly in the room where it needs to be used. There is an important point regarding the coverage check and the waiver. A coverage check was not carried out when I signed the new contract. The coverage check was only carried out after I complained about the coverage problem.
After I complained, the store carried out a coverage check and I was told that I had signed a waiver saying that I could not return the device if I changed my mind. I understand that a change-of-mind return is different from a coverage-related return. I am not trying to return the phone simply because I changed my mind. The reason I want to return it is because the EE coverage is inadequate where the phone is actually being used.
EE's current website states that if a device was bought in an EE store and the customer has coverage issues, they can return it to the same store within 14 days with the receipt, original packaging and accessories.
This is what I would like EE to clarify:
- Does the 14-day in-store return policy for coverage issues apply in this situation?
- Does a waiver relating to changing your mind also remove the separate coverage-related return option?
- Does it make a difference that the coverage check was only carried out after I complained, rather than before I signed the new contract?
- Does it make a difference that I was still in an existing EE contract, could not upgrade, and was instead sold a new line/contract on the understanding that this would resolve the problem?
- If the new line/phone has not resolved the coverage problem, what are my options for returning it?
I would appreciate an EE representative reviewing the situation based on the actual circumstances rather than treating this as a simple change-of-mind request.
I also have a copy of the document/waiver that I was asked to sign, and the wording appears to refer to returning the device if I change my mind. I would be grateful if someone could clarify whether that actually prevents a return specifically because of insufficient coverage.
In-store location that messed up and missed sold me.  109 High St N, London E6 1HZ (High street north)
Thanks.
UPDATE AND SUMMARY
EE Coverage Issue, New Contract & Refund
I wanted to share what happened with an EE in-store purchase and hopefully clarify the policy for anyone in a similar situation.
My daughter was already in an EE contract and was told she couldn't upgrade because she was still within her existing contract. Instead, the store at 109 High St N, London E6 1HZ opened a completely new line and contract with a new phone, telling her this would resolve the coverage problem she was having.
It didn't. She still had extremely poor or no usable EE coverage inside the house, especially in the room where she needed to use the phone. It's shared accommodation and the house Wi-Fi is basically non-existent, so being told to use Wi-Fi Calling wasn't a practical solution.
When we complained, Newby the manger, who was dealing with us at the phone when I called in , carried out a coverage check. Importantly, this wasn't done when the new contract was taken out. It was only done after she complained.
The store then referred to the waiver she had signed, saying she couldn't return the device if she changed her mind. But this wasn't a change-of-mind situation. The new contract was taken out because of the coverage problem, and she had been told the new line would fix it.
I checked EE's published information, which says that if a device is bought in an EE store and there are coverage issues, it can be returned to the same store within 14 days. I also found EE information referring to coverage-related returns involving franchise stores.
There was quite a lot of back-and-forth with Newby and the store. The discussion kept coming back to indoor coverage, Wi-Fi Calling, the coverage check and the waiver. We kept making the distinction between changing your mind and having an actual coverage issue.
We then went through the technician checks and everything else requested. Newby was clearly trying hard to keep the sale, and the conversation became quite difficult at times, but after all the checks and discussions, the store eventually agreed to refund the new contract and phone. Side note you can ask the online team to explain everything you told them and the outcome and if you have any PDF send it to the online team but one massive thing is file a complaint if you don't file a complaint they won't do anything investigation on them.
The main reason I'm posting this is because I saw a lot of people mixing up the statutory 14-day cooling-off period for online purchases with EE's own coverage-related return policy for in-store purchases. They are not necessarily the same thing.
My takeaway: if coverage is the reason you're taking out a new contract, make sure you understand exactly what you're being told before signing anything. And if you want statutory 14-day change-of-mind protection, buying online is generally safer than buying in-store.
13 REPLIES 13
ee_user14
Prodigious Contributor
Out of interest, what made you think having another phone on the same network, would get any different coverage from an existing one?
WiFi-calling should resolve this, if the only issue is one specific indoor location. It's exactly what the service is intended for.
The reason for taking the additional line wasn't because we expected a second phone on the same network to magically have better coverage. She was still within her existing EE contract and was told she couldn't upgrade, so the EE store opened a new line and advised that doing this would resolve the coverage issue she was experiencing. Unfortunately, it hasn't. The problem is particularly bad inside the house, where there is little or no usable EE signal. Wi-Fi Calling would normally be a possible solution, but this is shared accommodation and the house Wi-Fi is extremely poor/unreliable. We can't reasonably rely on Wi-Fi Calling when the Wi-Fi itself isn't providing a usable connection. The reason we're asking about the return policy is therefore not simply “we changed our mind”. The new line was taken out after the store advised that it would resolve the coverage problem, and the coverage problem remains. If the only practical solution is to install separate broadband purely so the EE phone can make calls through Wi-Fi Calling, we'd rather pay for Virgin Media broadband and keep the existing SIM/arrangement that was working for her. We're simply trying to understand whether EE's 14-day coverage return policy applies in these circumstances, particularly given that the coverage check wasn't carried out until after we complained about the coverage problem.
@MichaelMD : No waiver is necessary anyway. The law about 14-day "change of mind" cooling-off periods does not apply to goods bought instore, where you have the opportunity of handling them & testing them.
I think people are mixing up two different things here. I'm not claiming a statutory 14-day cooling-off period because of a change of mind. I understand that doesn't generally apply to an in-store purchase. The issue is coverage. EE's own website specifically refers to returning an in-store device within 14 days where there are coverage issues. The waiver I signed refers to changing my mind, not to waiving a coverage-related return. I'm asking whether EE's separate coverage policy applies in this situation.
ee_user14
@MichaelMD wrote:
The reason for taking the additional line wasn't because we expected a second phone on the same network to magically have better coverage. ....the EE store opened a new line and advised that doing this would resolve the coverage issue she was experiencing. .... The new line was taken out after the store advised that it would resolve the coverage problem, and the coverage problem remains.
The EE store advised that a coverage issue would be resolved by taking a new line....... and a customer is willing to proceed.
They done much daughter dirty so does anyone know anyone from EE and is anyone from EE one here.
No, we are mostly users like you who "know" the EE Community staff who moderate it & answer general Qs, not specific to users a/c's.
But do EE store have to follow the EE policy on line because the EE policy have a policy about the instor including franchises.
ee_user14
They are not alone in that. A poor sales suggestion, yes. But that wasn't the only mistake made in that shop.
