Mobile internet dropping out
Alex1409
I think there's something wrong with the closest tower to Yelverton Road, Coventry.
I usually have no issues but starting Tuesday, the Internet keeps dropping out at random.
Has anyone had these issues recently?
26 REPLIES 26
Are you losing coverage completely, or just getting poor data speeds?
Local coverage issues can be checked on https://ee.co.uk/help/mobile-coverage-checker and choosing "check service status"
Seems to be data only.
For the speeds, they've always been poor but now things just become non-responsive.
Can't edit the previous post.
21:40 internet dropped out completely, I still received a text so that works...
Michael_D
Hi @Alex1409
Was there anything showing on the network checker that @bristolian mentioned above?
If you enter your post code it will show if there are any current works taking place in the area, and there is an option to report a problem if nothing comes up.
Does your data work better outside the area?
Michael
The network checked doesn't show up because of the lack of internet connection...
Works without a problem outside the area, so far...
Rach_H
Are you able to check the Service Status using the working connection @Alex1409?
Rach
No. I get an error...
Katie_J
Hi @Alex1409
I'm sorry to hear this.
What error are you getting?
Katie
