I cant get 5G anywhere having pixel 8
Benfried
Ive never had 5G in any town i have visited with either my old pixel 4a or newer 8.  My sim is very old, could that be the issue?
6 REPLIES 6
Northerner
Hi @Benfried
Are you on PAYG or pay monthly contract.
What tariff are you on if pay monthly.
Its called "sim plan 40GB £23" and it ended 1 jan 2022, but still works, thanks
EE SIMs are multi-technology, although SIMs from pre-2021 only support 5G in NSA mode. That means you should still see 5G coverage although your calls would be carried over 4G instead.
Have you checked on the coverage tool, whether the towns you've visited, should have 5G coverage?
https://ee.co.uk/help/mobile-coverage-checker
Thank you.
It's says 5G+.  I knew it would, its definitely not a network issue.
Could it be a contract issue?
Matt_124
It is possible that plan is not a 5G plan and may be limited to 4G, if I remember some of the old naming conventions correctly.
You may thus need to change your plan to access 5G coverage.
That's probably the right answer, thank you.  I'll ask 150
