Coverage in Thurnscoe
Leanne_T
Update: 25 July 2024
Our engineers have activated the mast onto the network this week, and full service has been restored to Thurnscoe. We will continue to monitor performance in the area.
Update: 11 July 2024
Over the past month, our engineers have experienced a slight delay activating the mast onto the network, due to circumstances outside of our control. Barring any further unforeseen delays, we expect the mast to be on air-by the end of July.
We will keep you updated on this post.
Update: 10 May 2024
Our engineers have installed the power supply at the site and we have been working with the fibre provider to agree a date to install the transmission needed for the new mast. We have experienced a slight delay arranging a date to access the area and expect the transmission to be installed by the middle of June. Barring any further unforeseen delays, we expect the mast to be on-air by the beginning of July.
Update: 04 March 2024
Over the past month, our engineers have been working with the site provider to access the area and install a power supply at the site, which we expect to be installed by the middle of March. We have been working with the fibre provider to agree a date to install the transmission needed for the new mast, and have arranged to access the area and complete the work needed by the end of May. Barring any unforeseen delays, we expect the mast to be on-air by the middle of June.
Update: 19 January 2024
Over the past few months, our engineers have been in negotiations with the fibre provider to agree a date they can access the area to install the transmission. Negotiations are ongoing and, once we have a date from the fibre provider and the transmission has been installed, we can confirm an approximate on-air date for the new mast.
Update: 12 October 2023
Over the past few weeks our engineers have completed building the equipment needed for the new mast. We are working with the fibre provider to arrange a date to install the transmission needed to integrate the mast onto the network. Once we have a date for the transmission to be completed, we can confirm an approximate on-air date.
Update: 15 September 2023
Over the past month our engineers have started building the equipment needed for the new mast and expect the build to be completed by the end of October. We have requested the transmission for the new mast from the fibre provider to integrate the mast onto the network. Once we have a date for the transmission to be completed, we can confirm an approximate on-air date.
Update: 07 August 2023
Our engineers are completing the final steps to start building the equipment for the new mast. Due to logistical issues with the deployment of the new site, we will be required to use an alternative transmission than originally planned to integrate the mast onto the network. Once the equipment has been built, our engineers can request the transmission needed for the new mast from the fibre provider and confirm an approximate on-air date.
Update: 20 July 2023
Over the past few weeks, the revised drawings have been approved by the site provider and our engineers can start building the equipment needed for the new mast. Due to circumstances out of our control, we have experienced a slight delay starting the build but, barring any further unforeseen delays, we expect this to be completed and the mast to be on-air by the middle of September.
Update: 22 June 2023
Over the past few weeks, our engineers have been requested to revise the drawings for the build. Pending a positive outcome from the revised drawings, we will start building the equipment needed for the new mast. Pending a positive outcome from the revised drawings, we expect to start building the equipment needed for the mast by early August, Once the equipment has been built, we can start integrating the mast onto the network and confirm an approximate on-air date for the new mast.
We are aware of a signal issue that is affecting some of our customers in the Thurnscoe area. Our mast in the area had to be removed from the existing site in May 2023, as this was requested by the landowner.
Our engineers began looking for a new location as soon as we were made aware our equipment had to be removed, and we have located a new area. We have completed the required designs and surveys to make sure the land will be suitable for the equipment, and our engineers have started to build the equipment needed for the new mast. Barring any unforeseen delays, we expect the build to be completed by the end of June. Once the equipment has been built, we can start integrating the mast onto the network and confirm an approximate on-air date for the new mast.
We’re sorry for any inconvenience caused. In the meantime, you may be able to use WiFi Calling to make and receive calls and texts over a WiFi connection.
For information on who can use WiFi Calling and how to set up this service, please see our Using WiFi Calling  Help page.
46 REPLIES 46
Do18
  • Hi
  • when is this problem being resolved has I’m getting dropped calls which is unacceptable when you’re trying to sort other things out the last update was on the 07/08/23 which is over a month ago, I’m now getting calls we’re my phone doesn’t ring and gives the caller a message to say I’m unavailable I find this rather frustrating and I’m missing being contacted
Leanne_T
Hi @Do18
Thanks for posting.
The main post has been updated with the latest information and can be found here Coverage in Thurnscoe - The EE Community
Leanne 🙂
Mike2107
Over 5 months without phone signal are EE going to be compensating those affected?
Leanne_T
Hi @Mike2107
If you are affected by the mast being offline, please get in touch with our mobile care team to discuss your options.
I’ve been contacting their technical department each month, which have given me the cost of my phone back each month. Worth phoning
Hans-C-Anderson
Hi Leanne
If you could let EE it's Christmas soon
We've scene Spring,summer,Autumn with phones that dont work, so let's go the full whammy....
Yo ho ho.. jingle bells jingle bells
Do18
When are we getting a further update once a month is not good enough to say it was supposed to be the end of October I signed up for updates and a few minutes later I get this message it’s a joke
Network update: The problem at S630LZ has now been fixed, we recommend you restart your device. If you have already done this and are still having problems, please call us on 150.
tried number of times to contact says they will contact me but dont so cancel direct debit until sorted !
Leanne_T
Hi @Hunted
Our Contact EE page has ways to contact our technical support team.
Once we have an update for the area, the main post will be updated.
Do18
Hi Leanne
it’s now been two months since we have had a update on the mast it has been built has it’s at the bottom of my road so has no one been getting regular updates at EE from BT
thanks
