Community Activity
iPhone 17 Pro Max
Morning all. Probably a panic post, but I ordered the iPhone 17 pro max and got an XKO order confirmation etc. since then, the tracking hasn’t updated but says it’s despatched? Any ideas? Thanks, all.
EE tv box pro setup
Hi we are new to having broadband, and have had the hub set up on Friday. The engineer left us to install the tv box. I have followed the instructions and have connected the aerial cable from the wall to the box, the hdmi lead and the power lead betw...
Rach157 by Visitor
  • 19 Views
  • 1 replies
  • 0 Helpful
New TV plug to short
Hi, we have new EE tv and are setting it up but the power cable plug that goes into the main TV box but the plug length is to short to reach where we need to plug it in. How can we get a longer plug that is the same and safe ? Thanks
Mcmx by Explorer
  • 44 Views
  • 3 replies
  • 0 Helpful
Confusion About Plan Status
I recently received a message saying that my tech bundle has been fully paid off. However, when I check my account summary, it shows my plan as “Out of Contract.” Can someone please clarify what “Out of Contract” means in this context? Does it affect...
Mobile banking
Cannot connect completly to mobile banking. Says connection problems. Try again later. Appears to me Not Fit for Purpose
App app app crrr...
Dear EE. I have been with you for more time than I know my wife. Please, can you ditch your app and start again from scratch. This will never work.You have bundled so many things in to the app that this concept of interactive tiles and no fixed menus...
Andrei by Investigator
  • 193 Views
  • 4 replies
  • 2 Helpful
