Cant make calls
Jessfuller70
Is there any issues today as I can text and use data but when I ring it ring for a second then cuts out. Check service checker it says its OK
The issue started today
The status checker is more directed at radio network/coverage issues than the issue you describe.
Are you saying calls are connecting momentarily then dropping out? Or are they not connecting in the first place?
Is this happening on calls to specific number ranges, other networks or specific individual numbers?
