Calls Fail
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-02-2023 07:11 AM
Hi, when I try to make a call to anyone it just says ‘call fail’ I can txt and use what's app but cannot make calls I have tried turning off and on and the airplane mode reset but to no avail. No problem with coverage or my phone iPhone 13. Are you able to assist please ? Thanks
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-02-2023 10:02 AM
Hi @Jenni44
Welcome to the community, we'll do our best to help.
Does your phone show that it has signal and connected to EE?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-02-2023 12:10 PM
Sent from my iPhone
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-02-2023 12:27 PM
OK, thanks @Jenni44.
Could you pop your postcode into our network coverage checker and hit the 'check status' button please? It will let you know if there are any maintenance works in the area and let you report a problem if we're not aware.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-02-2023 12:33 PM
Yes all seems ok with the signal
Sent from my iPhone
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-02-2023 12:41 PM
Could you try these steps please?
- Manually search for an available network. You'll find this in Settings > Mobile Data > Network Selection.
- Choose any non-EE network operator (this will fail, but it's part of the plan)
- Once it fails, re-search and select EE
Let me know if you're then able to make calls.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
01-02-2023 12:47 PM
@Jenni44 wrote:
Hi Chris, no all I have is a WiFi signal (when connected to WiFi)
Sent from my iPhone
Do you have WiFi-calling enabled? And a WiFi-calling symbol active?
If not, then your phone won't be able to use any mobile-network based functions without either having network coverage or WiFi-calling enable.
Usage of apps such as WhatsApp, Messenger & suchlike is only carried through EE's mobile network as data. It's not a voice call as far as EE is concerned, it's data traffic. This will be using your WiFi-connection.
