20-08-2025 10:11 PM
I have an account with NSI which requires two tier sign in , first on the website , then they ring and I put in the 6 digit number from my website page . But my phone doesn’t ring it just goes straight to voicemail
it use to work until the last apple update
any ideas please
23-08-2025 08:45 PM
A two-way SIM-swap may be wise here. It will categorically identify whether the phone is at fault or not.
Test a working SIM in the non-working phone - what result?
Test the non-working SIM in a working phone - what result?
21-08-2025 10:19 AM
Hi @Tenpin
Welcome to the community.
Is the number that's calling you in your block list?
Go to Settings > Apps > Phone > Blocked contacts.
21-08-2025 10:59 AM
Can you receive calls otherwise?
21-08-2025 11:53 AM
Yes
just this particular one goes straight to voice msg
my phone doesn’t even ring
21-08-2025 11:53 AM
No
21-08-2025 12:22 PM
OK, thanks @Tenpin
I suggest speaking with our Customer Support team so they can look into this from our side for you.
Please keep us updated with what happens.
21-08-2025 03:28 PM
Yes
21-08-2025 03:39 PM
When calls from specific callers are consistently being blocked, it's usually consistently with a device-level issue.
Try test calls to your phone with number withheld, see whether a "do not disturb" or "silence unknown callers" setting may be the culprit.
Otherwise - when the call hits your voicemail directly, see what number the call is from, assuming you have missed call alerts enabled. Then try intentionally blocking it in order to subsequently unblock it.
22-08-2025 07:43 AM
Spoke to customer support at EE
they did checks and said nothing wrong from there side
22-08-2025 07:45 AM
Going to put my friends phone in as a different contact number to see if my phone is the problem
