Bad signal
Options
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-03-2023 04:04 PM
Hi! My signal it's very bad, it works very well only on you tube but I can't use any other application on the internet or make or receive calls this is happened from 2 months ago
Options
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-03-2023 05:44 PM
The network signal is the exact same whether you're using voice or data, and regardless of which app you might be using on your phone.
Does your phone show the VoLTE indicator? What happens when you try making a call?
