Bad signal
Jodieleanne1
Since yesterday my signal have be so bad best I get in 1 bar and then I still can’t use it, and that keeps dropping out I can’t even call ee to discuss this issues as no signal
@Jodieleanne1   Use THIS to see if there is a network issue in your area.  You’ll need to click the check status tab.
@Chris_B @ it says my coverage should be great
Jon_K
Former EE Employee
Hi @Jodieleanne1.
Can you try tapping Check Status rather than Check Coverage to see if there are any issue in your area?
Jon
