17-07-2022 09:05 PM
I am having problem with signal of EE sim recently since 3 weeks. Mobile goes totally out of range . No calls no internet or texts. Im posting this with my home broadband wifi , have no coverage of sim card. Sometimes resetting or switching on and off did works but not most of times. Today i went MATLOCK city in a Fair and lost my signal there. No navigation no calls to find a way. I have tried everything but nothing work , had complaint of signal to EE but no one did bother to come back . IDK what should i do.
18-07-2022 07:59 AM
Thanks for replying, @Hsr147
I would suggest speaking with our Technical Support team so that this can be investigated further. They'll check everything from our end and hopefully have some options for you.
17-07-2022 09:17 PM
@Hsr147 Can you try a different EE sim in your phone ? to see if that gets a signal. It could be your phone or you might need to request a replacement SIM card as that could be the issue. As you say it’s in multiple locations so I doubt it’s the EE network that’s at fault as you’ll be using multiple masts to get a signal in different locations.
17-07-2022 10:01 PM
On the face of it, a lack of coverage for such an extended period across an extended area, is less likely to be a network issue and potentially a fault with your phone.
Trying another known working EE SIM with your phone, or your SIM in a known working phone, would be an excellent test.
17-07-2022 10:07 PM
Hi thanks for reply. This is 6 months old sim card . Actually E-SIM.
17-07-2022 10:10 PM - edited 17-07-2022 10:10 PM
Im using 13 pro max now. Due to network issue i hv changed 3 phones.
18-07-2022 07:59 AM
