Bad reception
Heather3787
The last 3 days my signal is dropping plus no internet while out
If you have no coverage, then it's normal for your calls, texts & mobile data to fail.
Using the "check status" option on the coverage tool is the best place to start. You can report suspected issues there too, if multiple EE users in the same area are all affected.
https://coverage.ee.co.uk/coverage/ee
