on 14-03-2026 03:02 PM - last edited on 14-03-2026 03:21 PM by Christopher_G
I've had no 5g coverage for 4 days after a storm. I've reported the fault at Dg8 0**. Any idea how long it will take to fix it
[Mod edit: Edited postcode]
Solved! Go to Solution.
on 14-03-2026 04:12 PM
Are you getting 4G coverage? Or nothing at all?
Reporting the fault via the status tool is absolutely the right thing to do - once the first-line network guys have taken a look, they'll be in a better position to ascertain what the fix is.
