New build postcode not recognised
5GEE
I moved into a new build 2 months ago and literally every service recognises my postcode except EE.
I can't check the signal in my area as it's saying my postcode is invalid. I can't sign up for network alerts as apparently my postcode is "not in the UK".
The only place where it works is the fibre broadband checker!
Is anyone here able to assist with this?
Christopher_G
Hi @5GEE
If you speak with our customer support team, they will be able to see if we can get it updated for you on our side.
I don't know how often EE update the postcode database, but can you use a nearby postcode as an interim measure?
Depending how urban/rural you are, the serving site(s) are unlikely to be vastly different over a short distance.
It's good that the EE BB Checker recognises it. Shows that postcode is registered correctly.
Yes that works, but it's only EE that doesn't recognise my real postcode. Vodafone, Three and O2 all recognise it
Christopher_G
Hi @5GEE
I could update the billing address without issue; it's just the network checker that's not working
