05-07-2023 05:56 PM
The signal strength has gone drom exceptional to barely usable recently
Does anyone know why this is?
Is it part of a prep for 5g?
or jsut broken?
Mac :¬)
26-07-2023 05:40 PM
Have all those neighbours reported issues? If not, they should do.
If multiple users from the same location report the same issues, it may hold extra weight.
26-07-2023 05:45 PM
ty Bistolian :¬)
Just got an email saying they checked and indeed its got a fault and will take around 7 hours to fix
Problem is instead of 0 bars ill be back to the 1 bar i have had to put up with for the last 5 months
<all appendages crossed> :¬)
used to be 5+ bars 100mbit thats how good it was sigh
my neighbours might have reported it but tbh they jsut use land lines mosly
27-07-2023 11:20 AM - edited 27-07-2023 11:20 AM
seems its being taken seriously
hope for more than 1 bar though - used to be 5+
"Network update: It’s taking longer than expected to fix the problem in ME14 XXX. We will continue to keep you updated. Your Report ID is 4572596."
all appendages crossed... again
27-07-2023 04:18 PM
still no bars must be a realy bad fault ID is 4572596
or no longer EE area
04-08-2023 02:49 PM
Just closing this off
It was indeed a repeater error and it as fixed
saddly instead of 5+ bars i only get 1-2 now but its sufficient to outlast my few months
Thanks all for reading
