Re: slow internet speed on mobile
Nickolphert
Hello,
EE user with unlimited data plan. My internet speed is terrible, this has only occurred in the last couple of months, I can be on 5G and videos barely load.
Is there an issue with the network at the moment or?
iPhone 14 Pro.
advise would be appreciated
7 REPLIES 7
Christopher_G
Hi @Nickolphert
Welcome to the community.
Could you check your postcode on our network status checker please? It will let you report a problem, if we're not already aware of one in your area.
Thanks Christopher.
The main area of issue is whilst at work, which is in the centre of Leeds city.
I’ll have a nosey on your network checker.
just done a speed test and the results are as below.  Post code LS1 4EE
 I can’t do that either 😞
Christopher_G
Could you try it on a different device or browser please, @Nickolphert?
ECR-teck
EE are the biggest fraudsters in UK
If you are on a cheap plan then EE have a CAP on your data speed to get you on there expensive plan
Rky
Prodigious Contributor
Please ensure you are on no max mbps plan
Best Regards,
Raj
I don’t follow, are you asking me to put this SIM card into a different device?
I can’t change what browser/server apps use….
