12-08-2023 09:52 AM
I have had no mobile data for two days now, tried all the fixes: aeroplane mode etc. status checker says problem fixed but still not data. Any idea what is going on?
12-08-2023 10:13 AM
Hi @Leeny41
Thanks for coming here.
Can you access data in other areas?
Can you make calls and send texts?
Leanne 🙂
12-08-2023 10:28 AM
12-08-2023 10:33 AM
Thanks @Leeny41
Do you know if any other EE users are having the same problem?
What happens if you try and make a call when not connected to WiFi?
12-08-2023 10:52 AM
12-08-2023 10:54 AM
Thanks @Leeny41
Do you have data remaining from your allowance?
Do you get an error when trying to access data?
12-08-2023 11:07 AM
12-08-2023 11:15 AM
Thanks @Leeny41
If you give us a call on 150, the team can check the area and see what could be causing this for you.
Leanne 🙂
