mobile boardband pockit hub.
Lukeg33
On my mobile boardband plan I have sms now do I use them?
LGreenwood
Most mobile routers allow you to read & reply to texts; some allow you to send. Login to it & look for the SMS section.
Lukeg33
that still does not help I know now to connect a device to it but I dont know now to login to it.
LGreenwood
& I don't know which router. Which do you have? Read its label.
Lukeg33
I have a 4G EE wifi.
LGreenwood
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover.
