password for braudband
tomascawthorne1
how can i find my password for my ee 4G internet box when ive lost the piece of paper with it on ive looked through the ee website as i have also not got my phone with me to contact them any advice would be appreciated.
@tomascawthorne1 : Which pwd, admin or WiFi?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
