What is 4GEE home unlimited and how can I improve it?
vhardy
TV goes blurry and freezes...we do not have fibre broadband in this area so we're offered the above, which we have had for a year.
All neighbours have Virgin...is this the only option for us? Anyway I can boost it, folks?
10 REPLIES 10
@vhardy : Try a speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
vhardy
That's slow! How does that compare with the Coverage Checker at your location?
'You'll get excellent coverage indoors and outdoors on your iPhone 13'
Fine until this week...any chance it's to do with the football??
James_B
EE Community Manager
Have you tried the 'check status' option @vhardy?
Where can I find the status option, please?
James_B
Hi @vhardy,
It's just next the check coverage option at EE Coverage & Network Status Checker.
If it doesn't see any issues, there is an option to report a problem.
Hope his helps. 🙂
Oh just found it:
No problems here...
"Network should be fine here. If you're having problems, flag it up and we'll investigate. Problems reported in the last hour may not appear straight away."
James_B
Please report an issue @vhardy and our network team will take a look at it for you.
Thanks 🙂
