5GEE router password not working
dheer1436
I am trying to connect Philips Hue lights to the app but it requires a 2.4ghz wifi connection and it can be done if I can access to 5GEE router by changing the Wi-Fi setting to 2.4ghz. When I try to log in it keep on showing 'incorrect password' I have tried to reset the router but no luck. I have been using the original password and never used or changed to another password. If anyone can help me out and navigate me how to log in/change to 2.4ghz settings please? Many Thanks!Screenshot 2023-11-27 at 21.32.56.png
1 ACCEPTED SOLUTION
Christopher_G
OK, thanks @dheer1436
If it still isn't working, I'd recommend speaking to our technical support team.
11 REPLIES 11
@dheer1436 : You are trying to login with the admin pwd, not the WiFi pwd?
The admin pwd should be found on a label on it or under the battery cover.
dheer1436
Thanks for the prompt reply. Yes I have been trying the admin password
You've done a hard reset, not just a reboot?
I have done hard reset as well by pressing micro button underneath the router 😞
Leanne_T
Hi @dheer1436
Thanks for trying this.
Did you try a pin or pen to press the factory reset button?
Leanne 🙂
Hi, yeah thats how I managed to reset the router
Christopher_G
I called them yesterday no luck I’m hopeless I’m sure there is away to fix but EE doesn’t know how to.
Christopher_G
What happened on the phone call, @dheer1436? What did they try with you?
