23-07-2025 11:52 AM
Hi All
As above if I use the standard address of 192.168.1.254 I get an error, site unreachable.
If I use 192.168.1.1 I get the admin page fine but at Advanced then system to change password I have no system setting.
I can change the wifi but not the Hub password .
I'm using my PC to connect.
Please advise.
Frank
23-07-2025 12:28 PM
@wavesound are you using the mobile smart hub?
This section is for Home Broadband, so the link @JimM11 posted may not help.
Not sure you can change as much on the Mobile Router but this link may help. https://ee.co.uk/help/broadband/mobile-broadband/4gee-wifi
23-07-2025 12:19 PM
23-07-2025 12:28 PM
23-07-2025 03:25 PM
Hi thank you .
I'll try the link it is the mobile one.
Cheers
