Unable to find out how much data I’m using
Bernie-b1
I have recently purchased a camera for ponies field. I have purchased a data only sim payg. I have registered but it is saying that I need to complete registration. I have put sim into a phone to register it. Sim is activated and working well in camera. I can’t access how much data I’m using or top up page. Any help would be appreciated. Sim is pre loaded with 120 gig of data so I know it’s not going to run out too quickly but would like to be able to keep an eye on it. Thanks
7 REPLIES 7
@Bernie-b1   If you login to your EE account it should show how much data is left on the sim and how much you’ve used so far.
Bernie-b1
Thanks Chris. I’ll give it another try
GradientWizzard
Hello @Bernie-b1
If you click on My EE at the top of the page, Click Data & Usage, then click Data Usage, you will find all the data usage in there.
If you are using a mobile phone, Login to the My EE app and scroll down, you should see "Your Data" just a bit further down. Hope this helps 🙂
Bernie-b1
Still unable to find how much data I am using. On registration page it still says I have to link. I have registered sim and popped it into phone to do that. Camera is working and recording with sim but I am stumped with the final part of registration
Thanks I’m not getting an option anywhere to find data usage on my ee
Katie_J
Hello @Bernie-b1.
When the SIM is inside your phone are you able to text BA to 150? if yes, does this show usage?
Katie
Hi Katie
I haven’t tried that. I will do that and see if it works. Thanks
