Does the 4G broadband router have multiple Ethernet ports?
thusband
Valued Contributor
Valued Contributor
I'm currently an EE mobile phone customer but am interested in 4G home broadband. Can the provided router act as a home hub with multiple Ethernet connections like the router I'm currently using? I'm located in rural Somerset and have Voneus as a provider.
Thanks for any comments.
@thusband : Which of EE's mobile routers are you looking at?
  • If it's a 4GEE WiFi it has no Ethernet.
  • If it's a 4GEE or 5GEE Home Router it has 2 Ethernet ports.
thusband
Valued Contributor
Valued Contributor
I need at least 5 Ethernet ports so I guess it would be the Home Router with an Ethernet switch to get more ports. A switch would work right?
Thanks for the quick reply.
