Trying to connect Wi-Fi to device, but it says ‘Incorrect Password’
Persona_Cas
Hello,
I want to connect a device to WiFi and I need to type the password. I use the correct password but unfortunately I always end up with an error saying “Incorrect passoword”
I could connect other devices by using QR code, unfortunately this one device requires me to type down the password manually and I always end up with ‘Incorrect passsword’ error. Even if it’s correct 100%
I would appreciate help,
Northerner
Hi @Persona_Cas
The password cannot be correct, are you connecting to the correct network.
Try Factory Resetting the router & then login with the WiFi pwd written on the label on the router.
Mosab12
P*************** not it's slow, slow
[Mod edit - removed password, please don't share these details in public]
Debbie_G
Hi @Mosab12.
Sorry to hear things have been running slow.
It’d be helpful to understand a bit more about what’s happening. As this is an older thread about Wi‑Fi passwords, it would be best to start a new post with a bit more detail on the issue and what you’re seeing, and we can do our best to help.
Debbie
@Mosab12 Hopefully that is not your wireless wifi password you are posting, one more oops like that you just may get trouble.
@Debbie_G May be worth you blanking out the password before anything else get's posted up!
