Router VPN Compatible
Mariuk
Spoiler
Spoiler
Spoiler
Spoiler
👋Hi folks,
TL;DR: Is the EE B625- 261 Router VPN compatible? 🤞
I have  an EE B625- 261 Mobile Router and a subscription to Surfshark. Am I able to install the Surfshark VPN onto this router? 🤔
If not, what are my options? 👀 Can I buy a compatible router (recommendations most welcome) and just insert the EE sim card?
Thanks in advance,
Mari 😊
1 ACCEPTED SOLUTION
https://support.surfshark.com/hc/en-us/articles/360010780059-What-routers-are-not-supported-
"You will not be able to use these routers with Surfshark (at least with their default firmware):
Arris
Belkin
Cisco
Linksys (except Tomato supported routers from this list)
TRENDnet
TotoLink
Ubee
Google WiFi
****Most ISP-provided routers*****"
5G mobile routers are expensive and you would need one that hasn't been locked down by the ISP, most of the second hand ones are former "THREE" or "EE" branded ones so will have their custom firmware.
I don't know if your EE router has a "modem" mode like Virgin cable  routers which allowed you to plug your own router into it so you wouldn't need to buy a 5G SIM router. If it does you can buy one of surfsharks recommend routers and plug it into the EE router. If it doesn't have a "Modem" style mode it might cause other problems and possibly not work at all.
The cost of a new router might exceed what you want to pay to get your smart TV working the way you want it to. I think some people use amazon firestick for this which would be cheaper than a new router so you might want to research doing it that way instead.
https://support.surfshark.com/hc/en-us/articles/360018591494-How-to-set-up-Surfshark-on-Amazon-Fire-...
Also if you have a laptop you might be able to install the vpn software on the laptop, connect the laptop to the EE router with a network cable then use a free hotspot program ( eg https://mypublicwifi.com/publicwifi/en/index.html) to make a hotspot using the laptops wifi which you could then connect the TV to; this seems a very convulated way to get VPN working on your TV but won't cost you anything to try if you've already got a laptop.
https://support.surfshark.com/hc/en-us/articles/360003103833-How-to-set-up-a-router-with-Surfshark#h...
"For general guidance, we recommend routers running AsusWRT firmware, which is really easy to set up with a VPN. Here are several Asus models running this firmware: RT-N66U, RT-AC56U, Asus N-16, RT-AC66U, RT-AC68U, RT-AC87U, RT-AC5300, RT-AC3200, RT-AC3100, RT-AC1750, RT-AC88U, RT-AC66R"
@Mariuk : You can't install a VPN on a router but you may use VPN thro' it.
You may insert your EE SIM in any router.
Thanks XRaySpeX 👍
I'm probably understanding this wrong then 😳 -  I thought you could run a VPN on a router (as opposed to just having a VPN installed on devices that connect to the internet via the router).
The Surfshark website talks about running a VPN on the router so that you can get the benefits on devices like smart TV's:
Maybe you can, I dunno, but not on any EE router.
Arris
Belkin
Cisco
TRENDnet
TotoLink
Ubee
Google WiFi
Thank you uStoleMyCredit.
Casting from my laptop (which has the VPN installed) or a Firestick seems like the way to go.
