03-03-2023 10:06 PM
Hi team,
Can I use the 5gEE mobile router (QTAD52E) with another non-EE SIM? If does anyone who unlock the router bein dedicated to EE?
04-03-2023 12:52 AM - edited 04-03-2023 01:01 AM
Depends how old the Router is, its a Sierra Wireless 5G Module so there is a good chance it may already be unlocked but there are no guarantees, best bet is to slap another Network Providers Sim into it and see if its askes for an Unlock or Sim Network Unlock Code.
If it is Locked you best bet is to contact EE Customer Services and see what options you have to Unlock the Device, if do able a small fee maybe charged.
Note, if this is a EE Branded 5G Router, it will have EE Firmware Installed, so even in an Unlocked state it may not support other Network Carriers Bands or perform in the same way as the Original Manfacturers Unlocked Specification(s) .
04-03-2023 08:15 AM
Thanks for the tips and just to confirm it’s the EE branded device type.
any ideas how the firmware could be updated to allow other SIMs?
04-03-2023 08:16 AM
If it is locked, you may be able to request the unlock of the device through our customer service team, @DazzaH66
07-12-2023 05:11 AM
Hello, can you help me how to unlock the band? I'm using ee abroad but can't use 5g. Thanks
07-12-2023 07:28 AM
Hi @johnynguyen
Do you want to unlock the device to use another network SIM card or set up roaming?
07-12-2023 09:47 AM
I can use the sim but my bandwidth is limited. I want to open it up so I can use all the frequency bands of the device. thanks
07-12-2023 09:50 AM
The developer has restricted the bands and I cannot use the 5G bands,Thank you for your feedback
07-12-2023 02:19 PM
Thanks @johnynguyen
Are you currently using the EE SIM?
Can you connect to data using the EE SIM?
Does the roaming network have 5G available?
07-12-2023 02:56 PM - edited 07-12-2023 02:57 PM
Re above, do you mean to use 5G as in 4G+5G or use the 5Ghz WiFi Band?
Which Router are you using?
