17-12-2022 07:41 PM
I was advice to buy a 5gEE router as by can not supply me broadband, the signal is poor though, is there a way of increasing the signal?
thank you
18-12-2022 08:55 AM
Hi @Chris19741,
What does the coverage checker report for your area?
18-12-2022 01:44 PM
If there were an easy method, a network would be able to offer 100% blanket coverage and they'd be very quick to do so! The coverage you get is what it is.
An external antenna is often a good solution in fringe areas. Check using the coverage tool linked above, whether the predicted service is broadly what you're receiving.
19-12-2022 01:18 PM
Hi
i’ve just checked and it says poor. However when I went into the shop they told me was good,3-4 bars. And I should have no problems. So looks like they just told me this so I would purchase one
19-12-2022 01:44 PM
20-12-2022 07:37 AM
Hi
i purchased online after being recommended it by to ee outlets, over 2 weeks so stuck with a device that doesn’t work for 18months
20-12-2022 07:50 AM - edited 20-12-2022 07:50 AM
Thanks for coming back to me @Chris19741
Please give us a call on 0800 079 8586 and the team will see what they can do to help you.
