No lights on mobile broadband
kmatyh
Hi my mobile 58 broadband is working but it doesn't have any lights. It's only been with me for only a month.
9 REPLIES 9
Peter_W
Good afternoon @kmatyh, welcome to the EE Community!
So we can best help you here, can you please let us know which model of router you're using?
Feel free to post a picture if you're not sure too 😊
Peter
This one. 
Alex_H
@kmatyh Thank you for providing the picture. No light at all would usually indicate the router is powered off, but you are saying it is still working as normal besides the light?
If everything is working, just not the light, it would suggest just a fault with the hub light. Have you restarted the router since it started? Or factory reset it via the pinhole button on the back?
Alex
Which router is that? It should have a label on it with the model name.
Hello, I did turn it off then switched it on still no light. Ill reset it tomorrow and come back on this
Hello , it's the mobile smart 5g hub
I did the reset as advised still with no light at all.
Hello, this mobile hub is under waranty? Can i drop by to amy EE shop. I bought this online
Thank you
Ali_A
@kmatyh
It would be best to contact Customer Care first to log the fault you're facing onto your account.
Contact Us | Help & Support | EE
Ali
