‎09-10-2024 09:46 PM
I have a mobile chip in a wifi booster for about a year now. The last month the wifi has been completely out. I have tried resetting it. I have moved the wifi box to differant areas but nothing helps. EE says there is nothing wrong but it's not tight
‎09-10-2024 10:14 PM - edited ‎09-10-2024 10:15 PM
What lights show on mobile router? What does its Connection Status say?
Is it on contract or PAYG?
‎10-10-2024 12:44 AM
It's showing up blue like it usually does and says there is a stable connection. I have also done speed checks on it and all is running well. Just won't let me use the Internet or go on any apps. Keep saying no Internet connection
‎10-10-2024 02:20 AM
But if you are running speedtests on it, you are using the Net.
‎10-10-2024 02:57 AM
That's the thing, it allows me to do wifi speed checks and phone calls but other than that don't work. Everything is showing up normal. It just won't allow the network to work.
‎10-10-2024 03:56 AM - edited ‎10-10-2024 03:58 AM
Phone calls from a mobile router! You don't mean actual phone calls, but iMessagee type data things?
Aren't you going to let me see your Connection Status?
Give us some examples of where it can't reach.
