15-09-2023 09:04 PM
Good evening,
We have set up a brand new 5g router from EE evening. I am experiencing two issues:
Thank you in advance.
16-09-2023 06:35 AM
An update. I have managed using the WPS function on the router to set up the WiFi in each of the rooms. Yes, the strength is that bad. It is now saying incorrect password which I know is true and enter it manually it still is saying it is wrong. Any help would be gratefully received.
16-09-2023 11:19 AM
16-09-2023 11:37 AM
In our connections window on our devices (Ipads, Samsung S21, Samsung A33 and Iphones). There is usually two failed connections and then it comes up with the incorrect password
16-09-2023 11:42 AM
Have you connected your devices to both the EE router's and WiFi extenders networks @RNewman?
16-09-2023 11:48 AM
It connects to the 5gee router and cannot on the TP link powerline WiFi extender as it comes up with the incorrect password message. It takes me two or three attempts to get connect back on the 5gee router.
16-09-2023 12:14 PM
Have you supplied your devices with the correct password for your powerline adapters @RNewman?
16-09-2023 12:43 PM
I tried supplying the extenders with their passwords, I am afraid that didn't work. We have a mesh system and so I have tried three different passwords. I have also tried to do it over the TP utility.
16-09-2023 12:45 PM
Hi @RNewman,
I'd recommend contacting the manufacturer of your WiFi extenders for support if your devices are unable to connect to them.
16-09-2023 08:10 PM
I did this, this evening and we spent an hour on live chat talking to TP link. We have discovered the LAN port on the EE 5g router is not working. I have now spent 7 hours only to find it is a fault with an EE product. I am strongly considering cancelling. This looking at various forums is not a uncommon issue. Am I entitled to a discount for a faulty product?
