Help with new 4gee home router
benashley
I will be working from home soon and just got the 4gee router, £50 per month with unlimited internet.
The sales advisor tested my post code and advised this would be suitable.
I am only receiving 16.4-20.2 mbps download and 2.65 Upload, I have my router by the window in the same room I am testing from.
A few questions please, I am not tech savvy in the slightest please bare in mind for any answers.
1. Is this speed normal?
2. Will this be suitable for home working?
3. What is the difference between the two options I have 2.4ghz and 5ghz, currently connected to 2.4ghz but I dont understand what these options are.
Many thanks for any replies
Ben
Yes, what you read is correct. If you just need WiFi coverage in the same room as the router, stick to the 5 GHz band
Leanne_T
Hi @benashley
Our EE Coverage & Network Status Checker | Check your signal will show you the predicted signal strength for the area.
This post 4G/5G Router now Showing 2.4G/5G - The EE Community helps explain the difference between the settings for you.
If you are having any problems with speeds, please get in touch with our technical support team.
Thank you Leanne, those links helped me understand.
Do you in your opinion recommend I use 5ghz rather than 2.4ghz if I only require the wifi in one room? I read 5ghz provides faster speeds in a smaller area where 2.4ghz is slower speeds but bigger area coverage.
Leanne_T
Hi @benashley
Please use the option that works best for you and the devices you have connected.
