29-08-2023 09:02 AM
Has anyone successfully replaced the EE firmware on an EE branded NR5103 router with the stock Zyxel NR5103 firmware. please?
I've seen a Youtube video showing someone going into the o/s via SSH and changing a setting that then facilitates this but they never actually did the firmware change.
Reason I ask is that I am led to believe the Zyxel firmware has more facilities as the EE firmware is locked down.
26-10-2023 07:34 AM
I have to say that EE's firmware is really bad. You have cut off too many functions and it is really a waste of its performance. Can you please optimize EE's firmware? If you can't do that, please unlock the firmware for us and let us return to Zyxel. At the very least, Zyxel can update the firmware development function to maintain our equipment. And you EEs are trash and can’t do anything.
26-10-2023 10:15 AM
Hi @SHIELD-S
Welcome to the community.
Is there a certain feature that you're trying to access?
27-10-2023 02:26 AM
First of all, ee cannot lock the frequency band. I mean N77.N78. Secondly, the USB interface on the back cannot be used. Generally speaking, normal router USB can be used to access the hard disk, such as the SMB function, and it does not even have the most basic bridge network function. Don’t you understand that you are already several versions behind the Zyxel firmware?
25-11-2023 05:44 PM
I agree with you
25-11-2023 05:53 PM
any updates?
20-06-2024 09:44 AM
Обновление выпустите для ЕЕ nr5103 , разблокируйте управление бэндами частот 🙏, либо дайте возможность откатить на прошивку производителя zyxel.
21-06-2024 10:42 PM
@SKYFF wrote:
Release an update for EE nr5103, unlock control of frequency bands 🙏, or give the opportunity to roll back to the manufacturer's firmware zyxel.
09-11-2024 08:43 AM
Бот зачем мне отвечать? Я пишу специалисту , тот кто в этом разбирается ,
09-11-2024 03:13 PM
09-11-2024 09:39 PM
@SKYFF wrote:
Bot, why should I answer? I am writing to a specialist, someone who understands this.
