TV box issues after powercut
Dragonette
Since having BT TV about 10 days ago, we've had 2 power cuts. Both times we've had to factory reset the TV box as it appears to "brick". The first time we had to get phone support but the latest one (last night) we have resolved ourselves. Firmware all up to date.
Is this common?
8 REPLIES 8
Alex_H
Hi @Dragonette,
Welcome to the EE Community
Sorry to hear you have been having some issues with your TV box. I have not heard this specific problem reported elsewhere. The Power cut may have caused some corruption in the memory or something similair.
Hopefully you don't experience any further issues but if you do I would recommend reaching out to our TV technical team for further assistance.
Alex
zulu17
Star Contributor
Star Contributor
A general powercut would likely affect your broadband hub  and other equipment and devices. So it is possible these might need to be restarted before restarting your  TV Box.. When you say brick what state is it actually in - factory rests are often  a solution that are over recommended  when a less dramatic solution would suffice.
Completely stuck on a screen which hasn't loaded and no ability to scroll or access any menus. Just completely stuck and a power off, wait, doesn't resolve it.
The problem is still occuring. Every time the hub loses connection to a power source the TV box needs a factory reset before we can use it again. Also oddly, our printer also loses WiFi connection and it needs reconnecting to the hub.
When did this last occur @Dragonette ?  There is a known issue with some EE hubs that won't correctly resume a network connection to TV Boxes, however your hub was updated Wednesday night with the fixed software version.
--SRB--
I know with my box, if it loses the wired internet connection at all, the box won't reconnect to BB again unless it's fully powered off - it  just says no internet connection. If there is a power cut - I would tend to let the BB come back up before powering the box on again.
@Dragonette your most recent post is an exact repeat of the one before - does this mean the issue is still occurring?
