August firmware update
AndyPK
Any idea when we are getting it?  Mine appears to be on an old version?  Though the table says it's the current version?
Confused.
And am having a few issues
Product code: Smart Hub 3A
Firmware version:
r4.26.3-R-1923144-PROD-80004
Maestro
Maestro
@AndyPK Forget about it, the table that EE has done is just Bogus at present, 6+ and 7 Pro linked together only the Pro has got and NOTHING else. You appear to also have the older version the SH30A as quoting PROD-80004
From the other day see below.
New router WiFi dropout - The EE Community
Pro got this and starting on the date shown, 6+ nada currently FW: r5.16.1-R-2011329-PROD-1 and the gui is at App Version 3.17.5 20/08/2026
AndyPK
Anyone else having Wi-Fi connections to the router drop out at 13:48 every day 😅
The log shows 5 devices reconnecting at the time. Didn't even think I had that many devices!
@AndyPK Pick a time say 4pm, switch the hub off before that for at least 5 minutes, that will clear it all out, back on at 4pm will take 4-5minutes to reboot connect and then you can watch see what happens from then on.
Is this what you explained opening post with something going on Hub wise?
https://192.168.1.254 web manager to your hub, should show you what you have and the total off your devices, hopefully you do recognise them all as being yours and yours alone.
