on 11-11-2023 05:28 PM
I have a mobile WiFi device with data only sim, how do I find out how much data there is?
Solved! Go to Solution.
on 11-11-2023 05:30 PM
Look at http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see data & credit status as well as its mobile no. at the top.
on 24-11-2023 12:16 PM
the link you posted does not work and I cannot find how to check my balance/data usage for a 4gee mini wifi router. I have the app and have tried the link too.
Best wishes
on 24-11-2023 12:30 PM
@Nazneen37 : It works from here.
on 24-11-2023 12:31 PM
Hi @Nazneen37
Can you try the link when connected to the WiFi device and open this link here - add-on.ee.co.uk does this work for you?
Leanne 🙂
on 24-11-2023 12:59 PM
Hi Leanne
It says Forbidden you do not have permission to access this resource.
Best wishes,
Nazneen
on 24-11-2023 01:02 PM
@Nazneen37 : Check that the link doesn't start with "https:" but with "http:".
on 24-11-2023 01:10 PM
I've checked and it says http:/
Best,
Nazneen
on 24-11-2023 01:12 PM
Also, just to confirm this is a mini 4g device, that I am using my mobile to connect to. My normal network is not EE and the micro SIM is in the 4g mini device.
Best,
Nazneen
24-11-2023 01:16 PM - edited 24-11-2023 01:23 PM
Yes, that's what the link is intended for.
EDIT: Hello, it's happening to me now. When you click on the link or type it out with it starting "http://" & it comes up with "Forbidden!" have a look at the full URL in the Address Bar & see if it now starts with "https://". If so, edit it back to "http://".
