on 01-05-2024 06:09 PM
I have received the unlocking code for my 4g hub but it also asks for the admin password. I have tried 'admin' and the passwords on the back of the router but no joy. My contract has now ceased, could this be why?
on 01-05-2024 06:18 PM
You contract or otherwise has nowt to do with getting into the router. What model mobile router is it anyway?
on 01-05-2024 06:23 PM
It's a 4gee router
on 01-05-2024 08:59 PM
There are many such. Isn't there a model/name on the label? Or post a pix.
on 02-05-2024 09:03 AM
Yes the model is B625-261
on 02-05-2024 12:58 PM
Have you tried factory resetting it in case the pwd has been changed from the default on the label? There should be a pinhole somewhere that you press down for 5-10 secs with a pin.
on 02-05-2024 05:53 PM
Thanks, I've reset and still no joy. Pretty sure it shouldn't be this difficult 😕
on 03-05-2024 09:56 AM
Hi @Dawn_T,
Please note the password is case sensitive, are you entering exactly as it is printed on the label?
on 03-05-2024 06:14 PM
Hi
Yes I've made sure that I have entered it correctly.
I've tried 'admin' and the Web UI password on the label but nothing seems to work
on 04-05-2024 08:21 AM
OK, thanks @Dawn_T
I recommend speaking with our technical support team to see if they're able to help with this.
