10-07-2024 02:50 PM - edited 10-07-2024 02:51 PM
I have an EE 5G data SIM in a 5GEE router.
Overnight EVERY night the router is disconnected.
It does not reconnect, nor switch to a 4G signal.
Settings are
I am having to restart every morning in order to force reconnection.
I have seen some older posts, but none with a solution.
Nothing on the EE service check page re. overnight works or anything like that.
Any suggestions please?
on 13-07-2024 01:18 PM
So disappointing.
I was with you since you were FreeServe dial-up. I only went down down this route when you wanted to up my monthly payment but provide a slower service!
If I get an EE sim from you will the problem persist, and will you fix it if it does? Are you band-sleeping 5G?
David
on 13-07-2024 02:34 PM
Can't you get to Check mobile coverage ? It also tells you about network problems in the area & allows to report 1.
on 01-01-2025 02:11 PM
What helped me with the same issue was turning off mesh compatible settings and limiting the wifi to either only 2.4ghz or 5ghz, I have no idea how it could've been related but it reduced the disconnections a lot (not fixed completely but MUCH better)
