5GEE router losing connection overnight
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-07-2024 02:50 PM - edited 10-07-2024 02:51 PM
I have an EE 5G data SIM in a 5GEE router.
Overnight EVERY night the router is disconnected.
It does not reconnect, nor switch to a 4G signal.
Settings are
- Network search mode: Auto
- Network mode: Auto (5G/4G)
I am having to restart every morning in order to force reconnection.
I have seen some older posts, but none with a solution.
Nothing on the EE service check page re. overnight works or anything like that.
Any suggestions please?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-07-2024 04:17 PM
I am having the same problem. 4GLTE to Zyxel NR7101 router, was very reliable but now disconnecting every night and not reconnecting without a restart in the morning. I am situated NW of Sheffield. How do I check if the outage is due to EE mast maintenance etc or other factors.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-07-2024 06:02 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-07-2024 06:38 PM
Hi @Profile closed,
Which router are you using?
Does the disconnection happen at the same time each night, or after a set period of inactivity?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-07-2024 09:12 PM
Thank you for the link, on checking I got this:
Good network, but there was a problem in your area (S350**)
Updated on 10 Jul 2024 at 9:03 PM
No explanation of what the problem was but hopefully that was the cause of my disconnections overnight and it will be back to normal now.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-07-2024 08:39 AM
Hi @DRocke
Thanks for coming back with the update 🙂
Hopefully the service is back to normal for you.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-07-2024 08:55 AM
Thanks for checking, no sorry it disconnected again last night sometime
after 2230 which was when I went to bed.
If it helps I can get the cell if that I I connected to from the router.
Regards
David
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-07-2024 09:07 AM
Hi @DRocke
If this has continued, please report this on the network status checker and the report will go directly to the network team to get this looked into.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-07-2024 02:26 PM
Hi Leanne
I was the OP and will report my issue (Exeter) too.
Is there any hope of a firmware upgrade for the routers so that it properly reconnects when a service is available again?
David
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-07-2024 02:47 PM
Hi @Profile closed
Thanks for reporting this.
The network team will keep you updated once the report has been looked into to let you know if this is an issue in the area and when this will be resolved.
- 5G Smart Hub - connection keeps dropping, ping shows 3.9% packet loss in Mobile Broadband
- EE Smart Hub Pro – Ethernet Ports Dropping Connection Overnight in Broadband & Landline
- EE TV Box Pro losing connection to Remote in TV
- IPlayer in TV
- EE Smart Hub Plus and Sky Q Connection Issues in Broadband & Landline
