04-07-2026 09:42 PM
My EE box has started to lose its connection to my wifi router. Just now was the 3rd time in 24hrs. Unplugging and restarting the box did not cure it. Each time i have to got into the settings and reconnect the box to the wifi. This last time, it was laborious and didn't want to connect, i had to go back out, go back in and eventually connected. Just wondered if others had experienced the same
05-07-2026 11:43 AM
Hi @Satch72.
Sorry to hear your EE TV Box has been dropping its Wi‑Fi connection. If it’s happening several times a day and you’re needing to reconnect each time, that’s definitely not expected behaviour.
If you’re connected over Wi‑Fi, could you try switching Wi‑Fi bands? For example, try 2.4GHz if you’re currently on 5GHz, or vice versa, to see if it’s more stable.
If it’s still dropping out after that, please get in touch with our customer support team, so they can take a closer look at what’s happening.
Debbie
