5GEE Router 2021 Outdoor Antenna Advice
Millsonius
Hi there,
I have the 5GEE Router 2021 and it will connect onto 5G sometimes but will often drop onto 4G. The 5G connection also seems to be slower with higher ping.
I am looking to purchase an outdoor antenna in order to improve my 5G signal strength, but I have no idea what antenna I would need.
The router has 4 vertical ports on the back, most antennas I have seen have 2 cables.
Currently as of writing this, it isnt connected to 5G, but this is the information listed on my status page, in other threads I have read this has been requested.
SIM Status : SIM PIN Verified
Connection Status : Connected
Network name : EE
RSRP : -93 dBm
RSSI : -84 dBm
Band : B3
Cell ID : 6100736
I hope that someone could shed some light on this.
Thanks in advance.
James_B
EE Community Manager
Hi @Millsonius,
You can find some useful information in 5gee router which antenna - The EE Community.
Hope this helps.
Thank you, i will give that thread a read.
James_B
No problem @Millsonius 🙂
