on 04-04-2023 06:03 PM
Hi, I have a 5g mobile broadband unit but hoping to increase signal a little more as I have maximum 3 bars. Does any one know which are the correct antenna that connect to the unit?
Thank you
on 05-04-2023 08:00 AM
Hi @Soyshi
Welcome to the community.
Have you tried moving it to different areas of the building?
on 05-04-2023 04:38 PM
Sure have. I don't receive 5g in most parts of the house but I have found it best in one of the windows upstairs.
I am hoping an external antenna will boost more, just don't know which one I need to buy!! I think I need a 4x4 mimo (whatever that is), just need someone with experience to confirm that's the right one and any suggestions to specific makes/models!
on 06-04-2023 02:42 AM
Before you start spending money on External Antennas or differing types, can you confirm the exact 5G Router Model you have?
Also could you confirm your approximate Location, or a near Neighbouring Post Code, please do not post up Personal Information, if you prefer you can send the info via Private Messaging.
