05-12-2021 11:54 AM
Hi
I've tried my ways and searched for many times. Everyone say that the admin password is under the battery cover. And yes they are right there is a password under the battery cover : "gasp-clear"
But IT IS INCORRECT! I have tried just typing "admin" or reseting the router itself and try again. Nothing works.
Can anyone help me?
05-12-2021 12:35 PM
Hi @SAliB ,
Have you already attempted a factory reset according to the device documentation?
This is usually done by using a pin to depress a hidden switch while the device is powered.
05-12-2021 01:00 PM
Hi @SAliB,
The password under the battery cover is your WiFi password.
The admin username and password should both be 'admin'.
Hope this helps.
05-12-2021 02:00 PM
As @James_B says that Password looks like WiFi Password, so you need to log into WiFi Access before you can access the Admin section.
Other alternative is to log into Admin page via a Laptop with a direct USB Cable.
05-12-2021 02:52 PM - edited 05-12-2021 03:36 PM
tnx @James_B and @EssexBoyEE
I've attached some files to show the problem better.
Whenever I go to 192.168.1.1 It redirects me to 192.168.1.1/index.html#/index .
I've tried WIFI Key either, same result and it doesn't work!
P.S. I've edited the images.
https://ibb.co/LSnp1mw
https://ibb.co/FWGZRbL
https://ibb.co/zNxycV2
https://ibb.co/zGRVMwf
05-12-2021 03:58 PM
05-12-2021 06:31 PM
06-12-2021 11:51 AM
Hi @SAliB ,
Is that a new device that you can return as faulty on the basis that the factory-reset information is bogus?
If it's second-hand, it's possible the cover may have been switched with another device so has invalid information (this would explain that both WiFi password and admin password are invalid). Comparing the last letter "r" in the password to the earlier "r" in the line, it's possible there are letters missing from the admin password so you could try various completions. This last is reaching a little as the password looks sufficiently complete with only light-printing of the last character.
The remaining option, as legitimate owner of the device, is to "hack" access to the device by searching for information online.
16-11-2022 02:59 PM
hi.mt password does not work and i did not reset my wifi.how can i connect to mini wifi
16-11-2022 03:10 PM
Hi @mehdiakbarifly,
Are you using the same password that is listed on the 'keep me card' that came with your router or under the SIM cover?
