14-07-2025 04:47 PM
I recently switched to EE Broadband and now I cannot connect my printer to the hub
Nothing is working. If it won't work then I want to cancel my broadband and move back to Sky. Ridiculous. It's a new printer too
Oh and since changing settings to WPA3 I now cannot load the router admin page, it just times out
14-07-2025 05:17 PM
@lukejamessss it may be new, but your printer has been around for a while and it's interfaces are not very modern.
Hi-Speed USB (B Port)
Ethernet: 10/100Mbps (auto switchable)
Wi-Fi: IEEE802.11 b/g/n/a12
Wi-Fi Security: WPA-PSK, WPA2-PSK, WEP, Administration password
Wireless LAN Frequency Band: 2.4GHz
However, as it does have an ethernet connection, you could just use that.
If you want to use WiFi, as it only has a 2.4Ghz band, your router has a Compatibility option, this will create a new 2.4Ghz WPA2 band which should make it easier to connect your printer.
Not sure what you have done with your settings, but stick and hold a pin in the reset hole on the back of the router should revert it all to standard settings.
14-07-2025 07:12 PM
Connect to your pc via cable and use the PC app to connect.
17-07-2025 08:51 AM
Strict WPA3 is a bad idea. Guaranteed you will have devices on your network that do not support WPA3, so they will be unable to connect to the Wi-Fi at all. Another aspect to this is the fact that WPS does not work with WPA3, so you're effectively switching off all WPS functionality by configuring WPA3 as the security mechanism.
What Hub are you using? If it's a Smart Hub Plus/Pro, then I would recommend: -
With a bit of luck, everything should now be connected?
