on 02-04-2024 11:10 AM
How to link 4gee to app, but don’t have facility to receive passcode. I need to find out how much data is left on my sim.
on 02-04-2024 11:16 AM
@12Greenleafe : Do you mean a 4GEE mobile router? If so, Most mobile routers can receive texts. Login to it & look for the SMS Section/Inbox.
on 02-04-2024 11:19 AM
Hi - thanks for your help, it’s a 4gee dongle type, so I don’t understand how I can receive a text?
on 02-04-2024 11:21 AM
What model is it? It should say on its label. Can you login to it?
on 04-04-2024 08:10 AM
Hi - it’s a EE71-2BE8GB3
4GEE-WIFI-2196-2.4GHz
all I want to do is find out how much data I have left on the sim.
When I try to link the Sim to the app it’s asks for the phone no of the sim card and then says it will send a passcode to that phone. It’s SIM card not a phone it’s a mobile WiFi (dongle) thingy, so there isn’t a facility to receive a my info like that.
can you help me solve this situation please?
thanks frustrated dongle user.
on 04-04-2024 10:23 AM
I recommend speaking to our Mobile Care team so they can try and get it all set up from our side for you.
on 04-04-2024 10:38 AM
Yes, I've got 1 of those. It's not a dongle but a 4GEE mobile router called the 4GEE WiFi Mini.
Login to it at http://192.168.1.1 with the admin password found under the battery cover. Then look at the SMS tab > Inbox.
