4gEE smart hub manager
Coneve
Hi
I’m trying to access the smart hub manager but the connection just times out. I’ve tried on multiple devices, both wired and Wi-Fi connected to the hub but nothing connects.
Any ideas what I’m doing wrong?
9 REPLIES 9
@Coneve  Have you tried rebooting the router?
There's no such thing as a 4gEE Smart Hub. Just which router do you mean?
What is the IP addy you are using to access it?
The model is : 4gEE router
I tried to access the hub manager with the 192.168.1.254 or http://eehub as I’ve seen other advice on here. Must not be the right thing tho
Yes I’ve tried that but it didn’t help
@Coneve : If that's a 4GEE WiFi router you access it from http://192.168.1.1 . You are reading articles about the fixed BB EE Smart Hub router but you have a mobile router.
sorry I should have said I was trying to set up some port forwarding and when I accessed the router there was no options to do this…all I could do was access my account. I thought I must be on the wrong thing. Is there a way I can do this?
If it's the 4GEE Wifi mobile router I'm thinking of, it has no Port Forwarding facilities. Why do you need them?
Ah ok…well thanks for the help and advice, much appreciated
